Fireworks unger Hood
Old Aug 27, 2003 | 07:46 PM
TArider21's Avatar
Unhappy Fireworks under Hood
The other Night I noticed there was arching on the ignition coil and two plug wires seemed to be arching. Replaced all plug wires with delco wires today, and it seems like my problem is worse, there are fireworks under my hood! I'm seeing spark everywhere. I have no clue where to start. Any answers or suggestions on how to fix my problem would be very appreciated.
Old Aug 27, 2003 | 07:51 PM
RobK's Avatar
Did you use dielectric grease around the plugs & opti connections?
Old Aug 27, 2003 | 07:56 PM
TArider21's Avatar
Question Dielectric Grease
I used dielectric grease on all of the plug wires, the boots, but not the boots on the opti.
Old Aug 27, 2003 | 08:17 PM
Be sure your coil and the ground wires attached to it are clean and tight.
Old Aug 28, 2003 | 07:30 PM
TArider21's Avatar
Unhappy Coil Ground wires
The second time i changed my coil, the braided copper ground wire broke at the connector, I tried fixing it by putting a regular connector on it, but it is not copper like the original one. Do you think this could be the problem?
Old Aug 31, 2003 | 05:48 AM
redimpss5's Avatar
shorting of plug wires can cause the coil to fail, but you will not see sparks
Old Aug 31, 2003 | 01:56 PM
TArider21's Avatar
Cool No More Arching, I Think
I was running the car without a muffler for about a month, put muffler on yesterday, and car seems to be running a lot better. But now my problem is the exhaust pipe is sitting on the cross member, and causing the car to vibrate when driving. Does anybody know how I can fix this?
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
