PCM for less worth it on a six speed?
Old Aug 29, 2003 | 08:47 AM
IrocManiac's Avatar
PCMforless worth it on a six speed? If someone else were asking this question I know what I'd tell them I just want ya'll's feedback also should I do it now for the CAI/Exhaust or should I wait till I do headers next spring?
Old Aug 31, 2003 | 05:35 AM
redimpss5's Avatar
cant beat byran's work!!
Old Sep 3, 2003 | 12:41 AM
IrocManiac's Avatar
anyone else got any comments/suggestions?
Old Sep 3, 2003 | 01:25 AM
atljar's Avatar
A tune will never hurt unless the programmer is an idiot. 6 speeds just dont pick up as much in the 1/4 b/c you cant play with the shift settings like you can the a4s. Personally, i would save your money until after headers.
Old Sep 3, 2003 | 03:31 PM
BigRich's Avatar
i needed it cuz i removed EGR, AIR, and went to 3.73 in M6 (speedo corr)
also, car NEVER overheats now. even in 90 F weather
Old Sep 3, 2003 | 03:45 PM
97Z-M6's Avatar
i would becuase you can disable cags air egr, fix speedo tell them to make the pe mode hit say 12.9 or so.
i think it would be worth. your also addign miles on there that your not even doing because of the speedo not being fix.
Old Sep 3, 2003 | 04:23 PM
varneyins's Avatar
PCMforless does a great job on programming. You really need this to get the max out of your engine, regardless of transmissions type. He'll reset A/F ratios, idle and a whole lot of things which will make you happy!
DirtyDaveW
Dec 1, 2016 05:37 PM
feistersLs1
Mar 12, 2015 12:49 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Injuneer
Dec 15, 2014 09:36 AM
