valve lash setting...
Old Aug 28, 2003 | 05:22 PM
RAL2478's Avatar
Question valve lash setting...
Anyone have experience, or had to reset valve lash due to light upper end chatter? it is faint, but noticeable, and I was curious if this is just valve lash that is out? you cant really hear it if you are listening to the enging outside, but noticeable inside with windows up and all ACC. off. It doesnt sound like an exhaust gasket leak, that I would have noticed outside. Any and all suggestions and input are greatly appreciated, and I thank you !
Old Aug 28, 2003 | 06:18 PM
joeSS97's Avatar
Probably your injectors you are hearing.You could try adjusting the rockers.It may help...
Old Aug 28, 2003 | 06:38 PM
RAL2478's Avatar
How might I go about adjusting them? Is that also known as "valve lash", or is that just giving a .5 turn on the rocker nuts? I have considered putting a set of roller rockers on it, if I have to get in there...something tells me I will be making a trip to Summit Racing after work tommorow anyways!! thanks once again!
Old Aug 28, 2003 | 11:56 PM
Many methods to set the valves here.
Lash is the space between the rocker arm and the tip of the valve stem. Hydraulics lifters use zero lash. "Preload" is the term used for the additional turns needed to center the plunger on the hydraulic lifter.
Old Aug 30, 2003 | 07:02 AM
RAL2478's Avatar
Thank you all once again!!!
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
