HELP!! Missing on 2 4 6 8
Old Aug 29, 2003 | 09:43 AM
NONO5.0's Avatar
We're working on a '96 Impy and we replaced the plugs and wires and tranny. After we put it all back together, now its missing on 2,4,6 and 8 cylinders Any suggestions on what to look for? We know its not crossed wires and it was working fine before
Old Aug 29, 2003 | 10:45 AM
Gripenfelter's Avatar
Make sure the plugs are making a proper connection with the opti on that side.
How bad is the miss? Is it missing at idle? Could be a bad O2 sensor or unplugged O2 sensor.
Old Aug 29, 2003 | 10:55 AM
BlownF1's Avatar
Did you verify the plug wires are in the right order? Don't rely on memory as far as the opti order goes, verify to the numbers on it. Maybe one of you thought the numbering started from the bottom versus the top, etc? That's about all I can think of... <shrug>
Old Aug 29, 2003 | 11:33 AM
NONO5.0's Avatar
Yea, that's what is so strange about it. I know the wires are hooked up correctly. We thought about O2's but if one of them were bad, wouldn't it throw a code for it as well?
Old Aug 29, 2003 | 11:58 AM
I don't know if the injector wiring is the same, but you might try looking at the injector fuses. How do you know it is 2-4-6-8 that is missing? Scanner?
Old Aug 29, 2003 | 12:53 PM
NONO5.0's Avatar
Yep, the P0300 code
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
