Battery/Alternator/Electrical problem arlington, tx
Old Aug 29, 2003 | 01:01 PM
whiTetAlt1's Avatar
My TA has been having starting problems lately. I replaced the original ac delco battery around may. The battery had alot of corrosion on the positive terminal, I figured I'd get a new one. So i got an interstate from sam's club and it has been doing just fine up until the last week. There is major corrosion once again and to start the car i have to mess with the positive connection until i hear the headlights making their grinding noise then i can usually start it. The connection is tight so i dont know why it seems to loose power and i have to mess with the positive terminal everytime. The guy at sams club checked the battery and said it was just fine. I am wondering what could be the issue, I really want to fix it. any help is appreciated
also, im looking for a trusty shop in the arlington area and im open to suggestions, thanks yall
Old Aug 29, 2003 | 02:10 PM
VegasZ's Avatar
Corrosion eats away at the terminal bolts causing a poor connection. A replacement set is $3 at auto zone. Also get the battery terminal grease to prevent corrosion in the future.
Old Aug 29, 2003 | 03:47 PM
You must remove all corrosion or it will just begin to grow back. Clean thoroughly with baking soda/water paste and/or replace the nasty terminals. It's amazing how a little corrosion can play havoc with the electrical system.
Old Aug 29, 2003 | 06:55 PM
rage366's Avatar
uta? sweet...i just graduated from there. yeah, im in arlington too.
i've had my share of starting problems, so if u dont fix it, let me know.
--shokor--
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Collector Car
Jan 5, 2015 10:58 AM
