Copper Spark Plugs.
Old Aug 30, 2003 | 12:02 AM
Fux0redImages's Avatar
Copper Spark Plugs.
I heard from a friend that the Autolite 104 copper spark plugs are good for an lt1. I know that platinum is the norm, anyone have any experience with these or know if this is true?
Old Aug 30, 2003 | 12:08 AM
AsianSensation's Avatar
I use NGK TR55 copper plugs. I swear by them.
Old Aug 30, 2003 | 01:24 AM
anyone else with copper?
Old Aug 30, 2003 | 05:27 AM
sssalah's Avatar
Platinium costs and lasts more than copper, its not good for nitrous though.
Old Aug 30, 2003 | 07:30 AM
Josh-'04 GTO's Avatar
Yeah, I was happy with my Bosch +4 plugs when I was still naturally aspirated, but switched to NGK TR6 plugs when I bolted the N2O on. I believe platinum plugs run very hot, and didn't want to risk detonation on the juice.
Old Aug 30, 2003 | 07:43 AM
LWM's Avatar
LWM
I also use the autolite 104's, been in there now for 3 years now, no problems.
The thing with the platinum plugs is the pucks on the tips get blown away, thus instantly opening your gap to .090 of perhaps even larger. There have been quite a few posts about this phenomenon.
Hope this helps
LWM
Old Aug 30, 2003 | 08:18 AM
Hope this helps
LWM
I think I'm gonna get the autolite 104s as long as they're not too expensive, you know a site I can order them from? I haven't seen them available anywhere.
Old Aug 30, 2003 | 08:30 AM
xxsaint69x's Avatar
i am pretty sure u suppose to use autolite 106 on N/A and 103 on a N20.
Marcin
Old Aug 30, 2003 | 08:37 AM
FastZinTennessee's Avatar
I'm running the champion copper plugs in my car. They work like a charm. Although, if you're running NA and no internal engine work, there really is no need to run anything other than the platinum plugs. But if you have plans for something bigger down the road, do the copper plugs.
John
Old Aug 30, 2003 | 04:32 PM
LWM's Avatar
LWM
Try your local Ford dealer ...
LWM
Old Dec 13, 2004 | 09:53 PM
ellodaddy's Avatar
Re: Copper Spark Plugs.
Hope this helps
LWM
what spark plug gap on the autolite 104's?
Old Dec 13, 2004 | 11:10 PM
SS MPSTR's Avatar
The Autolite is a great plug. I ran them for years with great results.
Old Dec 14, 2004 | 10:38 PM
LWM's Avatar
LWM
As I recall ... .035 - .038, but that was in a super charged application, you may want to go wider if the engine is normally aspirated.
Hope that helps
LWM
Old Dec 15, 2004 | 11:07 AM
Jeff95TA's Avatar
Stock gap is 0.050"
Old Dec 15, 2004 | 01:43 PM
WOT's Avatar
WOT
I use autolite 106's they work fine-especially for $1 a plug.
