those with svo injectors, HELP!
Old Aug 29, 2003 | 02:41 PM
CGrant's Avatar
Hi,
I just installed my 30lb svo's and I need a couple of questions answered.
1. I noticed that there are two slits in the top of the injector but the clip on a 95z only slides into the top slit, Is this ok, I dont want my injectors to leak gas!
2. There is a greyish colored cap on the bottom end of the injector, (where it slips into the intake manifold)
I just want to make sure that it is supposed to stay on, It looks like it is supposed to be on it all the time, Just making sure its not just a temp cap for shipping or something. I am not talking about the clear plastic caps that come off i.e. for shipping, I am talking about the grey ones that look like they are actually part of the injector.
Thanks!
Chris..
Old Aug 29, 2003 | 02:45 PM
Gripenfelter's Avatar
Thats really strange.
Mine just snapped into place. The connectors were identical to my stockers.
Old Aug 29, 2003 | 03:32 PM
CGrant's Avatar
I got mine from sumitt, they have a red top half, then the lower half is black, Then the end tip is greyish that slides into the manifold, I already have them on the car or I would take a pic with my camera.
Chris...
Old Aug 29, 2003 | 03:45 PM
96ZRDR's Avatar
Hmmm, I have the same ones from Summit, and I never took off anything, maybe that is why my car runs like crap when I install them??? Hmmmmm......
Old Aug 29, 2003 | 04:52 PM
JSK333's Avatar
You don't need the clips. They merely keep the injectors in the fuel rail when/if you remove the rail from the intake manifold. They aren't needed to hold the injectors in while the manifold is on, as torquing down the fuel rail bolts is all that's needed.
As for the gray cap... hm, take a look at the bottom of the injector. Can you see little dots/holes like a screen (where the fuel sprays out)? If not, chances are that cap needs to be taken off.
Old Aug 29, 2003 | 05:05 PM
anaik's Avatar
I didn't use the clips either. I felt better with the injector seated in the fuel rail. Like said they're not going to go anywhere. As mentioned the little gray cap is part of the injector and is where the fuel is injected from.
Old Aug 29, 2003 | 05:08 PM
gb95zconv's Avatar
I used the clips....they work fine...no leaks.
Old Aug 29, 2003 | 05:11 PM
anaik's Avatar
If you didn't take the protective end caps off they wouldn't have fit in the fuel rail or the manifold. Maybe yours didn't come with any. As far as running crappy, did you reprogram the ECM for the SVO's.
Old Aug 29, 2003 | 05:24 PM
CGrant's Avatar
Hi,
So far no leaks
When I put the bolts in the fuel rail they tightened down fine.
yes, you can see the little holes in the bottom of the injector, thats why I kinda figured that little greyish cap looking thing was supposed to be on.
I think I am just going to take the clips off, It's not leaking but it will make me feel better.
Thanks!
Chris...
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
