LT1 Block Question..
Old Aug 29, 2003 | 09:14 PM
Camaro_Maniac63's Avatar
Do the LT1s in the Corvettes come with 2-bolt mains or 4-bolt mains? Need to settle an arguement. Thanks.
Old Aug 29, 2003 | 09:21 PM
WheelmanZ28's Avatar
Only a few rare '92 Vettes came with an LT1 block with 4 bolt mains.
A mechanic i know got his hands on one and I'm trying to persuade him to sell it to me.
Old Aug 31, 2003 | 05:20 AM
redimpss5's Avatar
vette motor 93 to 96 have four bolt's
Old Aug 31, 2003 | 05:50 PM
nope, wrong
Only LT1s with four bolt mains were in some of the 92 vettes
Old Aug 31, 2003 | 05:53 PM
TreySpeed's Avatar
On permanent vacation
vette = 2 bolt main
f/b-body = 4 bolt main
i think that 92 inclusive
Old Aug 31, 2003 | 06:15 PM
EviLZ28's Avatar
Then why do I have a 94 vette block with 4 bolt mains and a 95 with 4 bolt mains?
Old Aug 31, 2003 | 06:19 PM
TreySpeed's Avatar
all vettes had 4 bolt mains. LT4 f-bodys had 4 bolt mains too but they are pretty rare.
Old Aug 31, 2003 | 06:20 PM
EviLZ28's Avatar
That is correct. ALL vettes came with 4 bolts.
Old Aug 31, 2003 | 08:16 PM
Definitely... ALL LT1 Corvettes are 4-bolt blocks. I checked in the Michael Antonick Corvette manual, and he indicates they are all 4-bolt mains, from the first ones in 1992, through the last of the LT1's and LT4's in 1996. I've never heard anyone even suggest that this wasn't true.
AND... this is the good part.... ALL LT1 factory replacment blocks were 4-bolt mains, so if you managed to get your F-Body LT1 replaced under warranty, you got a 4-bolt block.
George Baxter used the 4-bolt block from an LT1 Corvette for his "quickest LT1"... (9.04 @ 155mph in a 3,900# convertible.)
Interesting quote from the often referenced "Rebuilding the LT1" online article:
Although the LT1 was only around for five years, there were two-bolt and four-bolt blocks, aluminum and cast iron heads, regular and H.O. cams that came with long and short dowels, and three different front covers. There was also the "Baby LT1," the 265 cid version that was the standard engine in the Caprice from 1994-‘96. With all that in mind, let’s take a look at this family of engines and see what goes where.
BLOCKS
350 - There are two blocks, one with two-bolt mains and one with four-bolt mains. They both have the same 10125327 casting number, so there’s no sure way to know which one you have until you get the pan off. However, if it came out of a Corvette, it should be a four-bolt block, and if it came out of anything else, it was supposed to be a two-bolt. GM used the two-bolt block for everything but the Corvette because it had plenty of strength and it weighed a little bit less.
Hoping to hear some documented proof from WheelmanZ28 to support his position.
Old Aug 31, 2003 | 08:31 PM
TreySpeed's Avatar
thats a hell of a place for GM to do weight reduction
Why dont they just take some off the cam profile too
Old Sep 15, 2003 | 10:52 PM
Hotwire's Avatar
shew!! thought someone was going to call me a liar. I just pulled my pan and have 4 bolt mains, but it came out of a 94 camaro! The tranny had a ac delco refurbished sticker on it, so someone must have had the tranny and motor replaced under warranty. wonder what the story is on that one..
Old Sep 15, 2003 | 11:44 PM
I'm never listening to a word my mechanic says again.
Sorry, I was wrong. Leave it to Fred to make me look like an ****. Why don't u like me Fred? I like u
Old Sep 15, 2003 | 11:55 PM
ninetythreez's Avatar
Vettes had 4 bolt mains with "327" casting on them. F-bods had 2 bolt mains with same cast stamping. LT4s are 4 bolts like Vettes but different profile grind on crank. I know. I've worked on em all- Grand Sport Vette 4 bolt main block same as LT4 also by the way.....
.02
Old Sep 15, 2003 | 11:59 PM
Originally posted by TreySpeed
vette = 2 bolt main
Backwards, dude.
Old Sep 16, 2003 | 12:01 AM
TreySpeed's Avatar
Originally posted by shoebox
Backwards, dude.
wow
typo of the year
