reduce timing help for over heating.
Old Aug 29, 2003 | 12:59 PM
97Z-M6's Avatar
well its reall hot here in tx. well any way when i drive in to town the car warms up fast (210) it will go back down once i hit the hiway but not as fast as i would like. so do you think if i reduce the timing at the rpms i operate at in town and on the open hiway a little it will help keep it cool.
just an idea. please tell me yea or nea. or if its a tupid idea to begin with
by the way all this is with the A/C on. and i know that dont help.
Old Aug 29, 2003 | 01:13 PM
funina91ss's Avatar
210*with the A/C on sounds normal to me my car will heat up to that with the A/C on with it off it stays at 180* I also have a CSI pump.
Old Aug 29, 2003 | 01:18 PM
grygst76's Avatar
retarding the timing increases heat due to increased emissions and such increasing timing will be smarter most overheating is caused by less timing
Old Aug 29, 2003 | 01:19 PM
MADZ28's Avatar
If I remember correctly, someone did a test for closed throttle and found out that more timing actually kept the temperatures lower.
Old Aug 29, 2003 | 01:23 PM
97Z-M6's Avatar
ion is that you
becuase thats interesting. ive always heard the oppisite.
anybody with any more info on this.
thanks.
Old Aug 29, 2003 | 01:27 PM
MADZ28's Avatar
Yep, sorry... I registered this nickname on my work computer and forgot to log out.
Either way, here's the article. Interesting stuff.
funina91ss's Avatar
what are your temps with the A/C OFF I dont think you have a problem stock cars run 210-220 all day long with a/c off.. Plus what thermostat do you have in your car?
Old Aug 29, 2003 | 01:42 PM
97Z-M6's Avatar
160 stat and the fans to come on at 185 and off a 179
the car runs 160 175 with out the a/c on on the same day.
Old Aug 29, 2003 | 01:44 PM
97Z-M6's Avatar
you mean you actually have a real job.
funina91ss's Avatar
it all sounds normal to me. I dont think you will keep the temps down when in town just not enoguth air flow too keep the a/c condensor cool.. the heat from it is what makes the water temp go up.
Old Aug 29, 2003 | 01:47 PM
97Z-M6's Avatar
but i was just looking for a way to maybe cut back on the heat that the engine makes. to help compinsate
Old Aug 29, 2003 | 01:50 PM
MADZ28's Avatar
Do you have Water Wetter in your coolant? I've used it on several LT1s and noticed a good 10 degree decrease in operating temperatures with it.
As for the real job, yes, I do have one - I post on camaroz28.com.
Old Aug 29, 2003 | 01:53 PM
97Z-M6's Avatar
today it looks ike we work at the same place.
but yeah but its actually from last year so i dont know if it is no good anymore or not. i dont how long it last.
Old Aug 29, 2003 | 01:58 PM
97Z-M6's Avatar
ion i was going to email you the other day to ask you what are some good mph #s to start at when redoing the shift points a on a car with 3.73.
can you take the percentage of gear and multiply that times the curent mph setting and and it to it. to get a ballpark to start at.
the car has a 230 236 on a 112. i dnt know if that matters.
Feffman
Oct 9, 2015 05:42 AM
Richardan15
May 30, 2015 08:36 AM
Ken Cemo
Feb 13, 2015 08:37 AM
pologreen97z
Dec 2, 2014 10:42 AM
teedoff59
Aug 8, 2002 01:36 AM
