How come everyone with true duels have turn downs?
Don't get me wrong I like turn downs I'm just curious cause I never seen a true duel setup that did not have turn downs. I mean are turn downs that great?
You can end your exhaust at any point you want (consistent with local laws, and any class limitations where you race). If you stop the pipes before the axle, you don't want the hot exhaust pouring onto underbody components, and you don't want the exhaust resonating off the floor boards, so you add a 90deg turndown.
Turndowns angled "inwards" to limit noise at "tech" check....
If you chose to run the pipes over the axle, you can put whatever "ends" you want on them... turndowns, chrome tips, ricer coffee cans.... whatever you like.
Btw is their any real advantage to having shorter pipe and turning it down before the axle?
One option is to do like Injuneer said and turn the turndowns toward the inside of the car or even toward the outside of the car. I had mine turned just straight down. I may go back and put them back on but truy them turned inwards. Sounds like a good idea.
Cool, BTW are you guys putting mufflers on your true duels or running straight pipe?
If I run true duels I'm not going to run cats I just have to figure out if I need mufflers. Never really heard true duels up close though.
I went half way with a 45* angle turn downs-
http://www.geocities.com/kmook123/exhaust1
I have hornies header mufflers with turndowns and it quiets the car down a bit.
I have had alot of people look at my exhaust and say "damn, I bet thats loud" and then I start the car up and its not near as loud as they thought.
My exhaust ends just after the front seats and thats where the turndowns are.
I always had the same question as this thread. If you go to the link in the sig for my car and go to page 10 I think you will see the true set-up I am running on my 93. It runs over the axle, has an H-section, and runs out dynomax bullets with the tips in the original locations. email me if you have any questions.
TRUE DUELS=
TRUE DUELS=
F'n1996Z28SS
Aug 23, 2023 11:19 PM
formula79
26
Aug 5, 2002 12:21 PM
Geeterman
Aug 4, 2002 04:03 AM
