Fuel Pressure
Old Aug 29, 2003 | 10:34 PM
EviLZ28's Avatar
Fuel Pressure
Ok, quick question. Messing around with new motor and I am setting the fuel pressure. You set it with the vacuum disconnected right? I am running 30 lbs svo's so I am gonna set it at 43 psi with no vacuum. Is this correct?
Old Aug 29, 2003 | 10:42 PM
Depends what flow constant you put in the PCM. SVO's are flow rated at 39.2psi (no vacuum), but will work fine at 43.5psi (no vacuum), yielding about a 5% flow increase. But you need to tell the PCM what your flow constant is, based on the actual "no vacuum" operating pressure.
Old Aug 29, 2003 | 10:44 PM
EviLZ28's Avatar
I have it entered in my pcm constant as 31.61. Any good or?
Old Aug 29, 2003 | 10:46 PM
That is the correct conversion for running a 30# 2.7bar injector at 3.0bar.
Old Aug 29, 2003 | 10:49 PM
EviLZ28's Avatar
So My settings should be fine? Reason I ask, It seems to be really rich when I start it. I have to put it to the floor to start it after I turn it off. I dont have a Datalog yet as I am still putting the finishing touches on it.
Old Aug 29, 2003 | 10:59 PM
Does the pressure drop correctly when you attach the vacuum compensation line?
Old Aug 29, 2003 | 11:20 PM
EviLZ28's Avatar
Yes it drops down to about I want to say about 28 lbs when the vacuum is on. I am not sure right now as I took the Y-pipe back off. I installed a 2 3/4 diam. y-pipe and having to modify a couple of things to make it fit.
Old Aug 29, 2003 | 11:30 PM
When you attach the vacuum line, it should drop in proportion to vacuum. 5 to 8psi drop is normal... the higher value for a stock cam, the lower value for something hotter than stock.
Old Aug 29, 2003 | 11:32 PM
EviLZ28's Avatar
Well I am running a hot cam with LT4 heads and intake ported and polished. I had MadZ28 do a tune on it before I added the heads and intake. Let me put the y-pipe back on and see what the fuel pressure is idling.
Old Aug 29, 2003 | 11:52 PM
EviLZ28's Avatar
Ok I got it back in. I was wrong about the pressure. Its at 35 idling with the vacuum on. what do ya think? I think I am gonna have to get a running datalog in closed loop to better diagnose this thing. This thing sorta has a lumpy idle. It didnt have that before with the stock heads and intake. I also added the bigger y-pipe and high flow cat after getting the tune. I am pretty sure I am gonna have to switch some things in the computer.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
