Torque converter lockup switch install guide inside...
Old Aug 29, 2003 | 03:51 PM
RamAir95TA's Avatar
I installed a TCC lockup switch on my T/A this morning, and thought I'd share the information. I haven't seen a TCC install guide anywhere online for 4th gen. f-bodies (at least ones that don't have broken links anyway...), so I put it all on film. I hope this sees good use.
TCC lockup switch install.
Comments are welcome.
Old Nov 7, 2004 | 12:55 PM
Loadre's Avatar
Re: Torque converter lockup switch install guide inside...
Can you repost this to the public? I really need to do it and the link isn't working.
Old Nov 7, 2004 | 06:54 PM
1racerdude's Avatar
Link not working.
Old Nov 7, 2004 | 11:29 PM
T/A#4's Avatar
Sure need that info. I noticed I go thru the lights at 4900 rpm due to the coverter lockup.
Old Nov 8, 2004 | 12:48 PM
RamAir95TA's Avatar
I apologize for removing the article. The original instructions I had given were inaccurate, so I decided to take it down before someone caused damage to their car. I have since redid the install, but made no guide for the switch. I can, however, give you a quick run-down on how to do it.
NOTE: These instructions work for 1995 OBDI cars, and should work for every other year. If it doesn't, sorry.
Find the PCM connector D, and pin 11 (pin 11 should be a tan/black wire).
Remove 1" of insulation from the wire, and splice in a long length of similar gauge wire.
Run the wire to a single pole switch, then from the switch to ground. Make sure all connections are tight.
When you flip the switch, the TCC lockup solenoid will engage. Regardless of the switch position, the PCM will retain factory lockup conditions.
Here's a brief diagram...
PCM pin 11---------------------to TCC solenoid.
|__________switch_______ground.
Hope that drawing comes out nicely...
Old Jun 16, 2005 | 08:28 PM
C Man's Avatar
My Friend with his Auto LS1 car had a switch for lockup as well... however with an added benefit... he had a light in the switch as well.
Everytime the computer locked up the converter, the light would go on.... and if the switch was "flipped" the light would stay on all the time.
So u can actually tell what the computer is doing even when not using the switch.
Thanks for the info on the wiring.
armedtrigger
Feb 24, 2015 08:30 PM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
LT4Ryan
Jul 29, 2002 08:38 PM
