rears brakes rubbing...quick help
Old Aug 27, 2003 | 04:56 PM
z28marine's Avatar
i just replaces mt rear brake pads, but they seem to be rubbing on the rotor. When i drive i can hear them scraping on it. I used a c-clamp to push the piston in, but do i have to do it more? also, will tightening the guide pins too much cause this????
Old Aug 27, 2003 | 07:23 PM
doug1105's Avatar
nah, I did new rear brakes, new rotors, new pins on drivers side. still squeals like a ****.
do a search on:
rear axle
C clip
caliper shim
and you will get all info you need.
You will probably need to do the rear axle c clip and the caliper shim to fix this. That's what I'm gonna do.
Hope this helps
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
