PCMforless or Ed Wright
Old Aug 28, 2003 | 12:13 PM
notfastenuf's Avatar
I have an Ed Wright program right now. I havent had it dynoed but with what I have done to the car I think that it should be a lil bit stronger. Do you think that I could get a better tune with PCMforless
Old Aug 28, 2003 | 12:44 PM
96ZRDR's Avatar
What year is your car? I basically have the same mods as you, with tuning from pcm4less, and it was totally off. They suggested I got with Ed Wright, but for the price, I said the heck with it, I have everything I need to tune a chip, and will start this week end.
What are you running in the 1/4?
Many would say otherwise, but Ed Wright would probably the best tuner outthere. He is or was an actual GM engineer. He does part throttle tuning as well.
Good Luck.
Old Aug 28, 2003 | 01:11 PM
BUBBA's Avatar
6 of ...however Brian may be less expensive and I don't know if Ed still does this, but I believe he used to lock certain codes and if you have to have emissions testing you might have problems because they can't read it out.
Old Aug 28, 2003 | 03:36 PM
revtime's Avatar
PCMforless will definately be cheaper.
I have not had any work done by bryan so I can,t say whether he is good or bad.
I have an Ed Wright tune in the car now and its still working pretty good, I have some new mods so I need to go down and have him dyno tune it.
I am fairly sure if you give PCMforless all the pertinent data on your combination they will be able to give you a decent program.
Old Aug 28, 2003 | 03:53 PM
BUBBA's Avatar
Ed did my first program for my cam. I opted to have it reprogrammed by Brian (when I had my 4.10s put in for the speedometer change)because it was less expensive for re-programs in the future and because I needed to have Ed's program unlocked so I could pass emissions. Brian doesn't lock'em.
Brian said Ed's A/F was ok and just smoothed out my idle mixture which was nice.
95craz28
11
Sep 12, 2015 07:47 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
NewsBot
Dec 17, 2014 02:50 PM
Beast87GTA
3rd Gen / L98 Engine Tech
Sep 4, 2002 12:26 PM
91 Redd Sledd
Jul 15, 2002 02:18 PM
