help me solve my spark problem. *PICS*
Old Aug 29, 2003 | 08:42 AM
Dave Feerst's Avatar
OK, here is what i have done.
changed plugs
tried a known good plug wire on #1
swapped fuel injectors
passed a compression test
what else can I do??
Am I right in thinking that the high spark line in #1 is a reult of the problem not the cause of it. I think if it was high resistance in a plug wire or groung it would be high but the cyls would be functioning normal. They are not, both cylinders never hit more than 350 or so degrees, all of the rest are at 700 or so.
Pics are on the site at the bottom.
click me
Old Aug 31, 2003 | 05:38 AM
redimpss5's Avatar
did it do it before new wires? i would check to see if it is arcing some where! also check the coil
Old Aug 31, 2003 | 09:16 AM
no, but I changed everything but the block (not joking) at the same time as the wires. so that doesnt mean much. #6 was a wire. #1 is not, Im still confused on that one.
Aug 22, 2015 01:09 AM
War Engine
Aug 20, 2015 06:13 AM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
TGGodfrey
Aug 17, 2015 08:43 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
