What best converter for mostly stock?
Old Aug 27, 2003 | 02:32 PM
BamaZ28's Avatar
For a 1994 Forumla A4 with unknown gears, we are estimating 3.73's though. (about 2800 at 72 or so).....it seems to eb abnormally fast and powerful.
I want to get a higher stall for it, what is the best one to get, for performance. It will be stock engine for at least another year or two. And will I need to get a tranny cooler? Thanks
BamaZ28
Old Aug 27, 2003 | 02:34 PM
Green G0blin's Avatar
i would def. recommend a tranny cooler if you plan on moding your car.
and i wouldnt go past 2600 or 2800 on a stock car.
Old Aug 27, 2003 | 04:01 PM
WheelmanZ28's Avatar
First of all, If ur at 2800 at 72 MPH, u probably have 3.42s and not 3.73s. I've had both, and I was at like 3300 around when i was in the low 70 MPH range.
If ur going with a new Converter, I would recommend a 2800-3000 stall by Vigilante. I have seen ppl shave the most off their times with this converter. I'm also very happy with mine. A tranny cooler is definitely necessary with a higher stall, because ur going to be generating more heat through ur tranny fluid, and a tranny cooler and knock the temp down about 20 degrees.
canbaufo
May 25, 2015 12:01 PM
ChrisFrez
Feb 15, 2015 07:49 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Cam's maro
Dec 28, 2014 09:30 AM
joe777107
Dec 1, 2014 09:32 AM
