Water pump gaskets?
Old Aug 29, 2003 | 06:47 PM
naaz90's Avatar
Water pump gaskets?
Should i add some sealent (Red RTV) to the gaskets, or is just some gasket adhesive(3M) good enough?
Old Aug 30, 2003 | 01:21 AM
OneFlyn95z28's Avatar
I alway install them with red high tack. I have also installed them Dry but it makes them harder to get off the next time...and there WILL be a next time
Old Aug 30, 2003 | 03:58 AM
revtime's Avatar
I used gasket adhesive, Indian head gasket shellac, I love that stuff.
No problems, leaks, or anything.
Old Aug 30, 2003 | 07:13 AM
nateh's Avatar
Something else to try is Hyplomar gasket dressing (Permatex #25249). I have used it very successfully on several gasket surfaces. It seals but doesn't cure, so when you want to remove the gasket, it peels right away and the surface wipes clean. It's really good stuff.
Old Aug 30, 2003 | 07:48 AM
Don 97 SS's Avatar
Yeah, that stuff is cool. I find it also makes gasket installation a little easier as the gaskets stick to the surface and don't fall off our move around as much.
Old Aug 30, 2003 | 07:38 PM
Laymaster's Avatar
I used Permatex Orange gasket. You know the kind that's good up to 600 degrees Fahrenheit.
Old Aug 30, 2003 | 08:15 PM
RamAir95TA's Avatar
Plain RTV is fine for me.
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Queens94z28
Dec 20, 2014 09:11 PM
