ignition coil
Old Aug 28, 2003 | 09:34 PM
oaklandz28's Avatar
ignition coil
when replacing the inigtion coil is theres some kind of grease you put on? will it make a difference if its not on?
someone told me about it and wanted to see if it was true?
Old Aug 28, 2003 | 09:36 PM
RamAir95TA's Avatar
You're thinking of dielectric grease. It's made to prevent corrosion of the coil lead wire terminal on the coil. It won't hurt to not use it, but if you don't like corrosion, you should invest in some.
Old Aug 28, 2003 | 10:51 PM
AsianSensation's Avatar
Put some silicone grease between of the ignition coil and the coil bracket. It's to aid in heat transfer to cool the ignition coil module.
BTW, hey Joe.
Old Aug 28, 2003 | 11:00 PM
RamAir95TA's Avatar
Well hey Winger...
Fancy seeing you here!
Old Aug 31, 2003 | 05:42 AM
redimpss5's Avatar
out here in the bay, i would say no problem just to mount it and go
Kempster
Jul 7, 2020 11:00 AM
markzzzz
Aug 17, 2015 11:08 AM
asilomar244
Jul 12, 2015 05:53 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
