how to install pro 5.0
Old Aug 30, 2003 | 01:57 AM
Zerosheaven's Avatar
does anyone have a link to show how to install a pro5.0 shifter on a 95 trans am??
also, ive heard alot of you cut the shifter down a bit. what are you cutting and by how much, where will they do this and do i give any special directions to the person cutting it?? wich side do i cut?
thanks
Old Aug 30, 2003 | 02:52 AM
turbo_Z's Avatar
Re: how to install pro 5.0
thanks
its really quite easy to install w/o any instructions but if you still want some then try www.bfranker.badz28.com and search for one in there... im pretty sure youll find something useful.
i cut mine down an inch. to do this you have to cut some of the threads off the shifter handle. mine was actually marked where it was an inch which was nice. i cut it down with a hack saw.
Old Aug 30, 2003 | 07:44 PM
Laymaster's Avatar
I wrote up how to do it on my webpage...
http://go.to/trans-am
It's under tech articles..actually it's the only one there. LOL!
Old Aug 30, 2003 | 09:54 PM
?? couldnt find it ??
Old Aug 30, 2003 | 11:32 PM
RedPhenx's Avatar
from pro 5.0's website...
http://www.pro50shifters.itctv.com/p...tall+procedure
install isnt that hard, but you will probably have to remove the entire console, i did it without removing the bottom part with the center console, but it was a PITA
and!!! dont forget to tighten the bolts holding the actual shifter with a 6mm hex wrench.. dont just hand tighten it or it will come undone on the interstate going 75 from the vibration...
it took me about an hour to do, and that was through the console. if you take that part off, should be a lot easier
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
