View Full Version : LT1 Based Engine Tech
- timing chain
- installing guide plates?
- It is possible..
- in process of mods, need some help
- Emmissions/idle problems
- Just saw the worst up kept LT1!
- hey shoebox.....
- That thing on the back of the heads...getting them off??
- broken ground wire
- Spark plug compressor fitting.
- Electircal Issues
- 350 LC on a budget
- Forgot To Clearance Oil Pan...Help ASAP
- intake oil leak
- What kind of #'s do you think this 383 would put down
- so what am i lookin at?
- Delteq problem...HELP!!!
- where to jack the motor from?
- takes a while to turn over, SES light, need some help, may have found a few causes...
- What head casting numbers are the good numbers?
- 396 LT4 Build/buy
- Headers?
- Which connector
- AFR Hydra Rev
- holy burnt spark plug wire!
- New Opti Fixed My Low RPM Stumbling Problem
- SAR Question
- Manifold Air Injector..Where does it go???
- bigger valves with 10308-1 spring kit, anything else?
- Le3 383
- Car Flooding Problems
- DD2003 Results
- blowing blue smoke on new engine
- which will give out first?
- lossing oil
- Question about my heads on my 383 stroker (Ported lt1 castings)
- Headers and Y-Pipe
- Service Engine Soon Light (code #29)
- SES Light on 1995 OBD1 with OBD2 style connector..
- What To Expect - Approximate Cost
- Timing cover question...
- Any of you guys cars still shock you?
- Battle of the Bolts vs. AIRpump.
- What is this cam.....
- Hesitation and Backfire
- Question about Meziere WP running clockwise.
- starting/idling problems
- how can u makea cai made for a 93 fit a 94-97
- gas mileage?
- intake manifold gasket and rtv
- Heads/Intake options?
- How would I know if I damaged the valves?
- Clutch Fork Broke...How?
- Trying to get parts on GMPARTSDIRECT
- Slp Cai???
- Valve is making a claking noise??????
- long turnover time. . .
- I've about had it!!!
- i need 500 rwhp......
- magnaflow catback with LT's video??
- finally got some dyno numbers with my new heads
- Running 37# injectors on a 30# tune
- 1994 Z28 A/C Install
- Miss after nitrous use
- intake oil leak question...
- Leak around AIR fitting (ps lt's)
- running rich still....
- GMPP Lifters, any one run them?
- fellow GMMG guys...need some opinions.
- ever hear a power steering pump squeek?
- Vid of 10.72 @ 132.6 or 129.6
- got my 355 running....need some small help!!
- speaking of pushrods
- What size pushrods?
- MSD Ignition
- Noticed something odd while scanning the car...
- Extreme duty timing set water pump gear?
- sa rockers and guide plates
- pics of long tube clearence?
- Low coolant light came on, but its totally full.
- How good is a 3.23 gear for a A4 car?
- Track times - suggestions?
- Why Am I Bending Exhaust Pushrods!?!?!
- Fastest HOTCAM car???
- Granatelli MAF interesting results
- Intake bolt issues????
- Very Good Article on Beehive Springs in Corvette Fever SEPT 2005, pg 68
- what is lloyd elliot website?
- adding coolant.... any special technique u use?
- Hypertech 160 thermo Identification?
- Removing hood liner....
- Clutch Help....Quick, broken down on road.
- Starter run-on !!!
- Still have a problem.
- Removing PCM
- quick exhaust question
- 94 z28 bolt ons.
- AC Question
- exhaust leak before o2 make it run rich?
- pacesetter air and egr
- LT4HotCam to CC306 worth it?
- FUBAR'd my spark plug threads - any suggestions?
- HP #'s
- What springs do I need?
- exhaust manifold gasket?
- Paper gasket above where oil filter threads bolt to block?
- DTC Code 18 ?
- Valve stem/guide seals.
- Anybody modified GM 1.6 RR to accept over .575 lift??
- Motor mount install
- a/c KILLS power...
- Location of 90 degree elbow for LT1..Help!!
- miss in the upper rpms ????
- New best, 355 6 speed NA. 10.72
- need idea's on next mods...
- o2 sensor , how many and where?!
- My ScanMaster Readings
- Car won't idle when cold
- Jet Hot headers Y pipe question
- header mufflers
- EGR problems
- ypipe
- Trying to decide on what Catalytic Converter to put on.
- temp sensor?
- CC 305...What Springs?
- New Magnaflow Design?
- Need Help!!!
- good heads for the LT1?
- power steering failure
- Exhaust Cut-out
- Whine from engine bay on accel
- Injector Voting
- which headers to get???
- I can't take it anymore.
- Bypassing VATS...which resistors?
- Opti?
- How to tell if wires are bad?
- Idle
- Sealant on WP/Block surfaces?
- Huge misfiring problem. Did I damage the valves?
- Rich condition
- cylinder 3 & 6 missfire?!!!
- Will Magnaflow/Carsound cats fit?
- How hard is it to Remove the AC compressor?
- What valve seals to use on stock head with .570-.580 lift?
- Stumble. Again.
- Will this mess my engine up?
- Quick Crank Pulley Removal ?
- iron heads and 1.6rr's
- pulley question need help
- How do you tell PM rods from others?
- LT's and O2 question
- Just Did The I.c.m. Mod
- Electric Cut-out
- New Delco O2's and still SES!!
- Any suggestions why my exhaust is popping
- SES light on...Code P1444..whats wrong?
- Programing BCM
- 8.5 MSD wire owners , which wire is this? (its the little one)!
- How much more lift is gained from 1.6 rockers
- I smell gas
- 94 That Spits Sputters and Misses with only 60000 miles HELP ME!!!!
- AC only blows hot air, after a very warm shut down.
- Stock radiator POS?
- CARB numbers?
- need help with a part #, 1997 convertible switch?
- electric water pump wiring to fuse block. got a question
- dimpled intake surface?
- doing mods this weekend would like some tips/pointers
- Jesel or T&D shaft mounts.....
- most important arp stuff to get for 383 rebuild?
- a/c and pwoer steering pump problem
- wide band o2
- valve springs and lift
- what size header bolts do i need?
- Where to get a 95 timing cover?
- PCM question.
- Stock fuel system
- hub length
- New Setup
- electric cutout
- HP Estimates?
- Yet another "need help, car is missing" thread
- 383 Stroker
- How does slp dual/dual sound w/ ory & lts
- HELP!!!!!! I can't take it anymore! Dropping volts under load.
- How long is Mobil 1 good for?
- Issues w/ Solid Roller setup
- Old LT1 Problem never resolved
- Rebuilding your LT1 Specs.. Need a list "possible sticky"
- Egr?
- HP gains with Mac Headers
- Low Oil light
- skip water pump?
- Any problems with only having one high flow cat ?
- LT1 to LT4 Cam question
- GM CAM valve timing points
- LT1 arp head bolts?
- Hypertech!!! why so expensive???
- Air Conditioner help.... newbie
- 383 or 398 (NEED HELP ASAP)
- O2 Extensions for Kooks
- How much am i looking at?
- Automatic 350/355 LT1s dynoing 360+ or trapping 110+ What's your setup?
- Guess on how much HP this combo would make?
- Catalytic converter warranty??
- Dex Cool or the green stuff...and internal engine cleaning...
- Hooker or Loudmouth
- Belt Tensioner help.
- Am I OK with stock fuel pump on 383 rebuild?
- Dan From J Ville Blk Firehawk
- Questions on Gm 847 cam
- Dead OBD port!
- LE2 questions
- Weird starting behavior
- what are all the gaskets i need?
- new squeeking noise
- HELP, LOW RPM MISS. Opicspark???
- intake manifold..
- question on 96z backspacing offsets question??
- Will LT4 roller rockers work on an LT1 stud?
- LT1 oil leak
- Coolant boiling out of fill tube...
- Got my report card (Dyno)
- yet another newbie with a injector question
- About to give up! MISFIRE
- Madwolf tune on stock Z
- head and cam setup
- ICM- spacers or buy a new one
- MSD Opti
- Lost the bolts to mount the tranny to the block.. what kind/size do I need?
- Cheaper Duals setup...?
- removing fuel pump questions
- is my hub on all the way?
- Bad miss in my 94
- Mezier WP Instructions/Opti Instructions?
- Planning a new race engine, need opinions.
- Ported back to stock
- Coil problems need help.
- need part number for lt4 km
- Can you tell if these comp cam 1.6 rr's are SA? Thanks!
- Take a look at what i found...
- How to interpret datamaster data recording
- oil choice for 194,000 mile Z28?
- SLP or Hypertech 160* thermostat??
- Rounded Head Bolts Removed
- Jet hott fitment issues
- for u cally guys lt4 hotcam kit passes smog
- what is the le2 cam?
- metal shavings!!!!
