sa rockers and guide plates
Old Jul 28, 2005 | 09:01 PM
92/95TransAm's Avatar
what makes self aligning rockers and pushrod guideplates not able to be run together? i have guide plates and self aligning rockers and was planning on installing them tomorrow, but i will have to send one or the other back if they will not work together
Old Jul 28, 2005 | 09:12 PM
Valkyn71's Avatar
Re: sa rockers and guide plates
You just dont need the guide plates if you have S/A rockers.
They help keep the pushrod inplace for Non-Self alligning rockers.
Old Jul 28, 2005 | 09:27 PM
what makes a self aligning rocker self aligning? what exactly does it align?
Old Jul 28, 2005 | 09:34 PM
simple's Avatar
pick up one of those self aligning rockers, you will see 2 little "lips" on the pushrod side of the rocker body. those lips keep the pushrod in alignment unerneath the rocker
EDIT; without those lips (or guideplates), the pushrod would come off the lifter and hit the valvecover or something and bend or do some other abnormal act causing a problem with the motor in more ways then one sometimes
nonSA rockers do not have those lips, so guide plates are used instead
from what i have gathered from some people, the SA rockers are a tiny bit louder....(?) probably not very noticeable tho
EDIT again lol; or if the pushrod doesnt have something too hold it in place under the rocker, the rocker can rotate freely in a circular motion which doesnt do much good when you want it too rotate up and down. can lead too premature valve guide wear because of side loading the guide if the rocker isnt "centered" on the valve stem
Old Jul 28, 2005 | 09:43 PM
do you have pictures of non self aligning rockers or know where i can get a picture of a non self aligning rocker so i can compare to mine just to see the difference
Old Jul 28, 2005 | 09:47 PM
simple's Avatar
now that i think about it, it might be on the valve side (roller tip) and the valve goes in the lips...**** i cant remember
actually, i think thats right...the lips are there too hold the rocker over the valve stem. they serve the same purpose as guideplates for NSA rockers
sorry
Old Jul 28, 2005 | 09:55 PM
ok that makes more sense now. i see the lips on the valve side of the rocker.
what is better off? using non self aligning rockers and guideplates or using self aligning rockers?
Plus doesnt it take aftermarket valve covers to use non self aligning rockers? the ones i bought are from scorpion they are narrow body self aligning i did not see any that were narrow body non self aligning.
Old Jul 28, 2005 | 10:02 PM
simple's Avatar
no, it doesnt take aftermarket valve covers. if they arent the narrow body rockers, it will usually take some bending of the supports under the cover....nothing big, pliers work good here
i dont know the details between the 2 styles as far as what is a better design (it could be all personal preference for all i know...)
i'd say too use what you have and not worry about it too much ($IMO)
Old Jul 28, 2005 | 10:05 PM
cool thanks for the help! i appreciate it.
Greg
Old Jul 28, 2005 | 10:06 PM
SStrokerAce's Avatar
Well the standard rockers that use a guideplate come in 7/16 stud sizes and that's what makes them better.
Bret
Old Jul 29, 2005 | 06:10 AM
why is a 7/16 stud better than a 3/8 stud? just because it is bigger? are there any other pluses?
Old Jul 29, 2005 | 10:25 AM
it's stiffer, so it deflects less and you get more accurate control of the valve which means more lift and less valve float or toss.
Bret
GREEN3112
Feb 10, 2019 09:19 PM
13qtr
Oct 28, 2016 08:11 PM
LT14LIFE
Nov 15, 2015 06:22 PM
Aaront810
Sep 11, 2015 11:24 AM
Daluchman1974
Sep 11, 2015 06:12 AM
