Dex Cool or the green stuff...and internal engine cleaning...
Old Jul 25, 2005 | 11:26 PM
phinger23's Avatar
Since im replacing the headgaskets (slowly but surely between work, school, weather and when im not in excrutiating pain), when its all cleaned up and back together, should i switch to dexcool? will i get any benefit? the dexcool is supposed to be more friendly on the gaskets supposedly? (the car is a 95 LT1)
also, before i get everything back togehter, whats the best way to clean out the motor from the crappy oil/coolant mixture? unfortunately, i dont have a garden hose readlily available (i live in an apartment, and doing this in the parking lot.) the radiator i can just yank out and take it to a hose and flush it out completely, but the motor is gonna be hard to do lol. but once its back together, i can run it somewhere (35 miles away) to families house and flush the coolant again and refill it but im not thinking thats a great idea.
any thoughts?
Old Jul 25, 2005 | 11:29 PM
Black1995Z's Avatar
Re: Dex Cool or the green stuff...and internal engine cleaning...
I recently asked the guys about the orange vs green and an overwhelming amount suggest green. Plus, if you switch you need to clean the other stuff out real well.
Old Jul 25, 2005 | 11:31 PM
phinger23's Avatar
yea, well since the top half of the motors gonna be out, id say thats a good time to clean and change if any
Old Jul 25, 2005 | 11:57 PM
turbo_Z's Avatar
I dont know which is better but I use the orange GM approved dexcool and have not had a single problem I could attribute directly to the coolant whatsoever.
Old Jul 26, 2005 | 12:14 AM
black_95_z28's Avatar
just make absolute sure that you don't have any green coolant left in there. If you mix the green with Dexcool it basically turns to jello in your block. I just filled mine up with the yellow mix with all makes and models ****.
Toole
D1SC383LT4
Jan 26, 2015 01:41 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
Bearmans
Dec 3, 2014 05:28 AM
