Question about my heads on my 383 stroker (Ported lt1 castings)
Old Jul 29, 2005 | 09:10 PM
NVetro's Avatar
Hey all, i got my 383 stroker back from the engine shop today. I have a quick question about my heads, they are stock lt1 castings which are ported. On the driver side head toward the front on the exhaust port side there is a roughly 1/2" or so threaded hole that leads to the water jacket. I know this is for the coolant temp sensor. BUT on the rear of the passenger side head there is the same hole, same side, threaded into the water jacket also. I assume this is done to make the left and right heads interchangable? What should I use to plug the hole on the passenger side head since its not going to be used for a sensor. ALSO, on the front and rear of the heads there is 1 water jacket on each head on each side, this i assume is also to make them interchangable, does anyone know the part number to those plugs so that i can cap the water jacket holes in the front of the head since the lines will be in the back? THanks alot!
Old Jul 30, 2005 | 01:28 PM
NVetro's Avatar
Re: Question about my heads on my 383 stroker (Ported lt1 castings)
No one knows?
Old Jul 30, 2005 | 01:31 PM
Dave89IROC's Avatar
um, use you old ones.........
Old Jul 30, 2005 | 01:36 PM
NVetro's Avatar
I want to new ones since the heads i bought did not have them in one spot and was the wrong one in another.....Is this a dealer item? Or can I goto home depot and get a pipe fitting or something....?
Old Jul 30, 2005 | 03:22 PM
importeater's Avatar
Call Jason Cromer - 877.726.8295
Old Jul 30, 2005 | 03:57 PM
NVetro's Avatar
Craig u dork :-P
Old Jul 30, 2005 | 04:32 PM
i'll remember that..
Old Jul 30, 2005 | 04:46 PM
NVetro's Avatar
So I found the P/N for the small plugs that go in the front of the heads they are 1/4-18 pipe fitting. GM PN: 144011 But i still cant find what is used to plug that threaded coolant temp sensor type hole on the passenger exhaust side of the head, toward the rear.
Old Jul 30, 2005 | 08:42 PM
Dave89IROC's Avatar
the one in the side should be 3/8 pipe thread(3/8NPT)
Old Jul 31, 2005 | 12:33 PM
Measure the threads on the coolant temp sensor that fits in the hole
Old Jul 31, 2005 | 01:08 PM
sssalah's Avatar
The small ones on the front are 1/4 NPT and the one on the side is 3/8 NPT with pn 14090911. Both can be found at hardware stores.
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
deadmanrunning
Jan 3, 2015 01:12 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
