timing chain
Old Jul 30, 2005 | 06:31 PM
lt1street's Avatar
timing chain
Helped a buddy this weekend replace his timeing chain. To me the chain feeled really loose you could push the side of the chain (parts the are not riding on the sprockets) in about a 1/2 on each side, is that normal?? We have not got to putting the new one on yet. Correct me if im wrong do you think my friends car will run better or stronger with replaceing the really loose timing chain, Not think it will give more power just thinking might run better with a tighter chain
Old Jul 30, 2005 | 06:48 PM
1racerdude's Avatar
Re: timing chain
LT-1's have a loose chane anyway. If ya replace anything,replace it as a set 2 sprockets and a chain.
Ya can get a Cloyes with standard SBC crank gear(they call it oversize) as an LT-1 has a smaller size GM spect gear and are made by Cloyes.
Old Jul 30, 2005 | 07:59 PM
lt1street's Avatar
Re: timing chain
will that just give the tighter chain or will it inmprove power wise or anything?
Old Jul 30, 2005 | 08:04 PM
lt1street's Avatar
Re: timing chain
Also the timing cover and opti-spark drive are 92-93 model but the motor is a 94 do you guys think its alright or is that something off the wall to have it mixed matched.The cover has two small hole one big instead of two big one small.And the opti-spark is drive by a splined driveshaft instead of a large dowel pin
Old Jul 30, 2005 | 08:27 PM
1racerdude's Avatar
Re: timing chain
As long as the cam is made for it it will be fine. It is a step back going to a '93 opti.
Old Jul 30, 2005 | 08:29 PM
lt1street's Avatar
Re: timing chain
but is the timing chain stronge as 94-95 on a stock motor
Old Jul 30, 2005 | 08:40 PM
1racerdude's Avatar
Re: timing chain
Should be the same chain set.
Old Jul 30, 2005 | 11:27 PM
Re: timing chain
93-94s are the same splined opti drive.
Old Jul 31, 2005 | 01:36 AM
lt1street's Avatar
Re: timing chain
thats what i though but the timing set i got is for a new lt1. so i dont know maybe missed boxed.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
