350 LC on a budget
Old Jul 30, 2005 | 02:29 PM
steves97z28's Avatar
350 LC on a budget
would it be possible, to build a LC 350 with forged pistons(rods if money allows) for a turbo. how much should this cost. trying to decide weather or not i should put the turbo on the stock motor, or take the car off the road now and build it over the winter.
Old Jul 30, 2005 | 03:05 PM
CustomSSI's Avatar
Re: 350 LC on a budget
Steve,
You could always pull the heads and have the combustion chamber sized up a bit and/or put in a thicker head gasket. How much PSI are you planning on running? You should be fine with a stock engine if your conservative, do you have a MSD boost contoller box to pull timing? maybe look into one of those to be safe.
Josh
Old Jul 30, 2005 | 03:32 PM
as of right now i have just the kit, and fmic. i was told i should put new gaskets in the top end to be safe since i have to fix the intake oil leak anyways. i would be looking at 5psi with an FMIC to go with it. i will be smart and leave it a 5 to. i will get software and any other things that will help keep **** safe so its done right.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
HAWG
Sep 25, 2015 11:41 AM
MDZ28
Sep 7, 2015 09:16 PM
