Any problems with only having one high flow cat ?
Old Jul 26, 2005 | 09:31 AM
BigJustinZ28's Avatar
hey guys I have a question. I think my passenger side cat is clogged . If I were to replace it with the highflow catco replacement would it have any ill effects on the car and would it horribly unequalize backpressure between the two banks ???
Old Jul 26, 2005 | 11:39 AM
pHEnomIC's Avatar
Re: Any problems with only having one high flow cat ?
I dont like the idea of having a difference in power between cylinders. The stock cats dont flow all that bad so i dont think you would notice a difference but why not change em both while you're at it. They don't cost all that much and since one clogged, the other is probably clogged somewhat as well.
Old Jul 26, 2005 | 11:40 AM
madwolf's Avatar
Definetely change both at the same time.
Old Jul 26, 2005 | 11:54 AM
thanks , guess im gutting the lil bastards till I have money for a ypipe with cats
Old Jul 26, 2005 | 12:12 PM
madwolf's Avatar
Don't gut. Replace with pipes.
Old Jul 26, 2005 | 03:48 PM
ok im jamming a pipe thru those lil bastards lol , all we have here is visual inspection .
edit , im pretty sure the stock y-pipe runners are 2.5 inches in diameter right ?
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
