hub length
Old Jul 26, 2005 | 04:37 PM
speedmiser's Avatar
hub length
Just got my double keyed hub from Thunder. I'm sure they didn't use my hub, cause I sent it for a core charge refund some time after I placed the order.
But, like a bonehead , I forgot to measure my old hub before I sent it to them. While I did tell them I needed a 93 hub, I'd sure like to verify the size, before I give it to my machine shop and have them cut the matching keyways in the crank.
Can anyone tell me the correct lengths for the 93-95 hubs and 96-97 hubs? I've done searches and have only verified that there are 2 different length hubs for the lt1s - just didnt see anyone stating what those lengths were.
Old Jul 26, 2005 | 07:32 PM
blackztpi's Avatar
Re: hub length
my hub off my 94 is.....3.100" and the inner diameter of the hub is 1.235" (inner diameter taken from where it slides onto the crank)
i had my hub off laying in the garage cuz my new motor has an ati superdamper. thought i'd help you out!
Old Jul 27, 2005 | 02:01 AM
speedmiser's Avatar
Re: hub length
Thanks - suppose I've got the right one then - here's the measurements I took on the new one:
3-7/16" from end to end
3" from front face of the bolt holes to the rear of the hub
1-5/16" ID
Anyone have the measurements on a 96-97 hub for comparision sake?
Old Mar 18, 2006 | 12:08 PM
SiCk PuPpY's Avatar
Re: hub length
Time to resurrect. I'm in an exact same situation. I bought and balanced a keyed hub, but i'm not sure if it's the correct length for the Cloyes double-roller set up. The measured hub length is 3.130 from the hub opening to the hub face (the "ears"/ or mating point of the balancer. Is this the early or late style hub?
Cheers,
JD
AviatorDave
Dec 19, 2016 06:35 PM
13qtr
Oct 28, 2016 08:11 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
