Stumble. Again.
Old Jul 27, 2005 | 09:38 AM
1FstFormulaV8's Avatar
Stumble. Again.
The Formula started stumbling last week. This is different than before. Whenever I stomp it, it just falls flat on it's face. But, if I ease into it, it does just fine. I can't figure it out. I was thinking maybe the TPS or I have a plug wire breaking down? My first thought was the Opti. Any suggestions?
Old Jul 29, 2005 | 10:32 PM
Re: Stumble. Again.
Interesting!
Old Jul 29, 2005 | 10:46 PM
mourningyou's Avatar
Re: Stumble. Again.
plugs and wires.
my car started stumbling two weeks ago, and my first thought was to mail a crate of failed opti's to gm headquarters. it had a huge miss, backfiring, and no power. i changed all the plugs and they all looked fine. when i went back for the plug wires the next day, i got them all changed and when finished i noticed that one boot was totally cracked and the wire inside was destroyed.
now my car runs fine. i'd check the simple things first. $35 bucks and i was back on the road.
Old Jul 29, 2005 | 10:50 PM
96LT1TX's Avatar
Re: Stumble. Again.
I have found to check for a leaky water pump... if one of the bolts backed out it will cause a bad opti sounding problem. I just fixed a horrible stumble from re-installing my water pump. If it isnt that, then check plugs, wires, fuel FILTER, recheck plug wires
Nayr
Mar 3, 2023 08:34 PM
magman
Apr 15, 2016 03:08 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
4586
Aug 24, 2015 11:04 PM
