Am I OK with stock fuel pump on 383 rebuild?
just getting ready to get rolling on my 383 stroker rebuild and trying to make sure i replace anything important that i need to while everything is out. i still have have the original fuel pump in there....should i replace? if so, am i ok to go back with stock gm? if not, what are other options. it's going to be a daily driver and probably no more than 400rwhp.
thanks in advance!
thanks in advance!
Re: Am I OK with stock fuel pump on 383 rebuild?
you shoudl be fine with stock pump...I am pushing almost 400RWHP and have no problems with fuel (but I am using 42lbs injectors)...Just make sure that you get good tunning...
Sebastian
Sebastian
