intake manifold gasket and rtv
ok which side of the intake gasket do i put the rtv on, on the side that touches the head, the side that touchs the intake, or both? i need to know ASAP, thanks.
Re: intake manifold gasket and rtv
I guess the reason the intakes leak is because GM was too stingy on the sealants at esp. the rear of the intake. so it's important to be generous with the RTV at the rear mating surfaces. With a good quality gasket a proper torqing you should be ok. JMHO
Don't use sealant on the gaskets. Lay gaskets on, retain with the white clips, put a good bead of silicone on just the front and rear of the block and around the tabs of the gaskets.
CARiD
Jan 27, 2015 06:27 AM
Jul 4, 2005 05:00 PM
