AC only blows hot air, after a very warm shut down.
On 90+* weather, if I have the AC on while I'm crusing around, the coolant temperature will creep up past 210*. The AC will blow cold air until I shut it off.
If I don't give the car a few hours to cool after being that hot, when I get back in the car, start it up, it will only blow hot air. It doesn't matter how long it's been off, 5 minutes or 30 minutes, still hot air. If I give it 3 hours or so, it'll pump out cold air as normal.
Any guesses? Thanks!
Re: AC only blows hot air, after a very warm shut down.
i'm having the same problem in my 94 1500 chevy truck. my dad is an ase gm tech. he said -mine- is due to a freon leak, and the freon leak is making my "xxx" get too cold and is freezing it so it can't turn. therefor the hot air.
Jan 23, 2015 01:13 PM
95chwagon
Jan 13, 2015 09:19 PM
