SES Light on 1995 OBD1 with OBD2 style connector..
Old Jul 29, 2005 | 07:09 PM
kainZ's Avatar
How do you check these SES codes?
Do you use an OBDII scanner or an OBDI scanner? I'd assume OBD I, but if so, do you get an adapter from somewhere? Can OBD II Scanners can these in some kind of backward compatability mode?
I think its just an O2 sensor, but I'd like to check first anyway..
Old Jul 29, 2005 | 07:56 PM
JP94Z's Avatar
Re: SES Light on 1995 OBD1 with OBD2 style connector..
You'd need an OBD I scanner. Shoebox's site shows how to make it work from the 12-pin cable.
Old Jul 29, 2005 | 11:09 PM
Lt1t56's Avatar
If you dont mind spending $250.00, buy a Scanmaster. It reads OBDI codes and will help in the future if you have any other problems. I have had one 4 years, and definately money well spent. Cant even begin to tell you how many times it has helped me diagnose a problem.
Old Jul 30, 2005 | 12:35 AM
kainZ's Avatar
will lt1_edit read codes?
Old Jul 30, 2005 | 09:07 AM
the OBD-I versions of LT1_Edit come bundled with pcmcomm, which will read codes and scan the PCM. With a laptop and a cable, you can use free scanning software like FreeScan and TTS DataMaster (free for first 20 uses). For the cost of a cable (check AKM Electronics) its a good deal.
FreeScan:
http://www.andywhittaker.com/ecu/ecu_software.htm
TTS DataMaster:
http://www.ttspowersystems.com/diagnostic.htm
LT1_Edit:
http://www.carputing.com/
AKM cables:
http://www.akmcables.com/
My online writeup for ScanMaster:
http://members.aol.com/InjuneerZZ/ScanMast.htm
Gtpguy
Jan 26, 2015 04:50 PM
joe777107
Dec 1, 2014 09:32 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
