About to give up! MISFIRE
Old Jul 25, 2005 | 06:12 PM
'96WS-6's Avatar
Well my car is in the shop and it just had all new wires and plugs installed and they said that should fix the problem, well they took it out and it still popped a misfire code in cylinder 4, so he took it back in fooled around with it checked it again and then drove it it still misfires. WEll we are about outta options cuz the opti was replaced about 1500 miles ago. NE help would be greatly appreciated. Thanks
Vince
Old Jul 25, 2005 | 06:16 PM
Crazy95Z's Avatar
Re: About to give up! MISFIRE
Test the injectors next.
Old Jul 25, 2005 | 06:29 PM
'96WS-6's Avatar
Do the fuel injectors really have sumthin to do with misfires and ignition?
Old Jul 25, 2005 | 07:39 PM
Crazy95Z's Avatar
Well, since you said the opti, spark plugs, and wires are fine, the nex thing to check for would be leaky/sticking injectors. My friend just went through this on his 2001 Silverado, had a slight misfire. So he swapped coil packed and did plugs. Come to find out, he needed a new injector and hasn't ahd a problem since.
Old Jul 25, 2005 | 09:33 PM
BadBowS10's Avatar
Move the number 4 injector to the number 2 spot and see if the misfire moves
greg
Old Jul 25, 2005 | 10:29 PM
Wickman's Avatar
I was getting a lot of misfires on my wifes 96 Jimmy. It turned out to be bad injectors.
Old Jul 26, 2005 | 10:59 AM
'96WS-6's Avatar
Well boys and girls, it was a fuel injector stuck in full open so it was causing my engine to go crazy. Thanks for all the advice and help!
Vince
Old Jul 26, 2005 | 12:47 PM
Crazy95Z's Avatar
Glad I could help ya! Always love my car more when it's running right.
marlar98
Sep 12, 2018 07:18 AM
Schul365
Aug 22, 2015 10:00 AM
Rittmeister
Aug 7, 2015 01:13 AM
zajones
Jul 30, 2015 02:18 PM
Boss002
Jul 24, 2015 10:47 AM
