where to jack the motor from?
Old Jul 30, 2005 | 12:23 PM
JJJ93z's Avatar
Im replacing my motor mounts , due to a header install, the drivers side is in just need to put the pass side on after the mounts. my question is where should i put the blocks to jack the motor up? some said under the accs. bracket by the crank but i dont know if it will balance. also which side should i start on? thanks
Old Jul 30, 2005 | 12:59 PM
JJJ93z's Avatar
Re: where to jack the motor from?
anyone jack the motor up before? can i jack it under the oil pan?
Old Jul 30, 2005 | 01:14 PM
Dave89IROC's Avatar
I always do, block of wood at the back of the pan, the bottom of the sump
Old Jul 30, 2005 | 02:53 PM
JJJ93z's Avatar
good deal, thanks for the help. also does anyone know what size socket to use on that bolt , i tried std. but none seem to fit, and locating deep well metric will be a challenge.
Old Jul 30, 2005 | 03:11 PM
n2ceptor's Avatar
Check Shoebox's tech page..... I believe the answers are there.
Victor Lamb
Aug 26, 2017 02:52 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
BigWil
Mar 29, 2015 12:24 PM
rick350
Mar 16, 2015 02:59 PM
JasonD
Aug 16, 2002 11:52 AM
