Planning a new race engine, need opinions.
Old Jul 25, 2005 | 11:14 AM
rje's Avatar
rje
I'm planning to build 365 cid LT1 with AFR 210 LT4's, but I don't know which valvetrain to use hyd roller or solid roller. I'm leaning towards the soild roller in the 250/260 @ 0.050 dur range with 12.0 cr and shaft mount rockers. This will be a race car and nothing else so I'm not worried with manners, but I will be retaining the stock pcm for now so that means keeping the rpms below 7000 even though the engine will withstand much more. Any ideas or opinions will be welcome.
Randy
Old Jul 25, 2005 | 11:21 AM
Victory Racing's Avatar
Re: Planning a new race engine, need opinions.
IF manners are no concern I would deffinitely go with solid valvetrain.
Also what are the flow numbers for those heads, that will effect the camshaft you use greatly.
Staying with stock PCM shouldn't be an issue at all.
What are your goals for the car, ET or hp goal?
Old Jul 25, 2005 | 11:25 AM
CANTONRACER's Avatar
If you want to keep the rpm's down...use up the heads with more cubes.
I have a great set of AFR 210's...and it kills me knowing that I will be limited to 7000+/- rpm range.
What you might want to consider is (I am at least)...putting a nice single plane intake converted for EFI, speed density setup and shift the puppy in the 8000 rpm range.
Something else...once you start getting into big, big heads...you will need some better headers.
Old Jul 25, 2005 | 12:42 PM
rje's Avatar
rje
Nick, I don't know thw flow #'s yet but once the winter comes I'll know more.
I want to run 6.70's in the 1/8 and my car weights around 3400 with me in it.
Cantonracer, I would love to do just what you said, but my money isn't that long just yet.
Randy
Old Jul 25, 2005 | 02:17 PM
flatlander757's Avatar
can someone clarify what the difference between a solid and hydraulic roller are?
Old Jul 25, 2005 | 03:34 PM
rje's Avatar
rje
Do a search, it will be easier.
Randy
Old Jul 27, 2005 | 07:36 PM
camaro81's Avatar
wouldnt an LS1 be better?
Old Jul 27, 2005 | 10:10 PM
Once you start plugging money into things...things get interesting...LS1 or LT1.
For the matter...why not just go big block Chevy?
Old Jul 28, 2005 | 01:34 PM
SStrokerAce's Avatar
The lifters...
A hydraulic lifter has a built in "lash adjuster" that is pressure fed with oil thru the block to prevent you from having to set and adjust the valve lash like a solid lifter needs.
Bret
Old Jul 28, 2005 | 02:25 PM
rje's Avatar
rje
Chris: What's up loser! I haven't seen you in awhile, of course I haven been to rockingham in almost a year. You still racing that white rusted out sh!tbox? Maybe I'll see you at the track before the years out. Later
Randy
Old Jul 28, 2005 | 04:04 PM
camaro81's Avatar
I havnt been to rockingham very much either :P just once in the last year
i got rid of that rusted out ****box man i got a '95 z28, its nice to be able to cruise to the track with the AC on!
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
centric
Aug 15, 2002 09:04 PM
