Weird starting behavior
Old Jul 25, 2005 | 09:51 PM
madwolf's Avatar
Sometimes when I try to start the car, the start will turn then stop for a second (as if something is interfering with the process, sounding almost like a clunk), then turn again.
I think this started to happen after my M6 swap. (although it may be a coincidence)
There are no grinding noises or anything and the engine runs fine. The battery has a charge and the alternator is charging well.
Ideas?
Old Jul 25, 2005 | 10:15 PM
Re: Weird starting behavior
Got good teeth all the way around on the flywheel?
Old Jul 25, 2005 | 10:17 PM
madwolf's Avatar
I have good teeth, yea.... wait... nevermind, same goes for the starter.
Old Jul 25, 2005 | 10:25 PM
Alvin@pcmforless.com's Avatar
Have you check the starter houseing to see if its cracked?
Alot of guys will put them on with a impact, tweek them a bit and they will screw up exactly how you mentioned.
Old Jul 25, 2005 | 10:29 PM
madwolf's Avatar
I'll have to check it again, but when I put it on, it wasn't cracked. (I don't use power tools either)
I just recalled of my flywheel fiasco, so it may be related to it. I might need to try another starter if it keeps giving me problems. Thanks guys!
Old Jul 25, 2005 | 10:36 PM
I would check as those starter houseings are made out of a crappy aluminum. It isn't strong at all.
I had the exact same problem after I rebult the engine in my firebird.. I put a hairline crack in the starter between the two bolt holes. Probally 1 in every 5 tries you would just get a thud when trying to crank.
Old Jul 25, 2005 | 10:37 PM
madwolf's Avatar
Yep. That's exactly what mine does. Thanks, I'll check it out.
Old Jul 25, 2005 | 11:21 PM
JKDZ28's Avatar
I agree with Alvin, mine has done the same thing in the past.
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
jj71787
Dec 30, 2014 02:15 PM
NewsBot
Dec 3, 2014 12:30 PM
APS95Z28
Sep 5, 2002 10:21 AM
