blowing blue smoke on new engine
Old Jul 29, 2005 | 10:20 PM
93redlt1's Avatar
is this normal. do the rings have to get seated or is this a problem of too much fuel being dumped. i have le2 heads and 32 # injectors and 255lph pump with a pcmforless tune. the rings are molys along with forged pistons and rods all in a 355.
Old Jul 29, 2005 | 10:48 PM
ChevyTuffD.A.'s Avatar
Re: blowing blue smoke on new engine
The most likely cause is the rings not being seated yet. Blue smoke means oil is getting into the combustion chambers. Let the motor get a few more miles on it and it should go away. If it doesnt eventually go away then the rings may not be gapped right. But most likely they just arent seated yet. Hope everything works out for u. Peace, Dustin.
Old Jul 29, 2005 | 10:58 PM
HaynesFaithZ28's Avatar
If you have blue smoke then you have metal on metal contact. How is your oil pressure? Did you prime the motor prior to cranking it? Were the rings file fitted? I would look at all of these before I cranked it again so that you don't mess those good parts up!
94 LT1 Z28, Forged speed pro pistons, scat forged rods, moly rings, racing bearings, ARP main bolts, Comp Cam's 218/224 (.537/.545)lift, 1.6:1 roller rockers, racing port job w/2.02 intake and 1.57 exhaust valves, Hooker shorty headers and Hooker catback, B&M shiftkit.
Old Jul 30, 2005 | 12:36 AM
1racerdude's Avatar
If ya have less than 500 miles don't worry about it.When and if the rings seat it will go away.
Drive it like ya stole it.
Old Jul 30, 2005 | 01:56 AM
breakmyfootoff's Avatar
The rings probably havn't seated yet, give it a little time and it should go away.
Old Jul 30, 2005 | 05:35 AM
93redlt1's Avatar
yes it doesnt have any miles on it yet. it has only been run for bout an hr total run time. thanks for all the quick responses.
Old Jul 30, 2005 | 05:43 AM
Z-RATED94's Avatar
Beat the snot out of it to seat those rings.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Britbilly
Jan 7, 2015 08:49 PM
Hoodshaker
Aug 27, 2002 02:32 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
