removing fuel pump questions
Re: removing fuel pump questions
Read the Racetronix instruction regarding reuse of the plastic housing (bucket). They consider it essential for proper fuel tank operation.
Frequently, "yellow" connectors will have a "safety" pin pushed through them.
Not the bucket for the pump. I talking about on top of the assembly that outside the tank where the fuel line come out of the take. There 3 wires that run from the wiring harness and connects the assembly, theres a yellow connector there that connects power to the pump. How do you get that off?
What am I missing here?
I'm not sure if that's the problem, but it seems like I'm the only person trying to help.
"What we have here is a failure to communicate."
