running rich still....
Old Jul 29, 2005 | 12:44 AM
lt1street's Avatar
I have madz28 tuning an i love it but my car still runs right at WOT every shift and everytime i stabe the throttle black smoke some times there is a grayish black ??? carbon ???? still dont no what grayish black smoke is its really faint. But the running rich, is that problem other pple get after madz28 tunning or is it a diferent problem? Also might help you guys answer my question i get a back fire throw the intake some time at wot and when i drive through town at low rpms (crusien) and give it a little gas fast(still in gear).thaxs for any advise!!
Old Jul 29, 2005 | 12:46 AM
1racerdude's Avatar
Re: running rich still....
What is your fuel pressure?
Old Jul 29, 2005 | 12:50 AM
lt1street's Avatar
when i put in the 255 lph pump it was 44 psi
Old Jul 29, 2005 | 01:00 AM
1racerdude's Avatar
Vacuum hose off or on?
Old Jul 29, 2005 | 01:07 AM
lt1street's Avatar
On i dont know what it is off
Old Jul 29, 2005 | 01:12 AM
lt1street's Avatar
would i benifit with a adjustable fuel regulator, I was tolded that the computer will just try to compensate. is this ture????
Old Jul 29, 2005 | 01:35 AM
1racerdude's Avatar
Probably no benefit if the stock one is working right.
Computer can't change fuel pressure,but your o2's will correct for over lean/rich if the fuel pressure make's it run rich/lean but only within it's fuel map.
Call Madwolf and see if he has an answer as to why it is running rich 'cause he knows how it is set.
I think it's suppose to be 39 with hose on and 45 or so with hose off.Been so long since I fooled with a stock set up I don't remember exactly.
There are several sensors that will cause it to run rich at idle like the TPS.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
