How much more lift is gained from 1.6 rockers
Old Jul 26, 2005 | 10:44 PM
PUGHBOY's Avatar
Having a brain freeze. How much more lift is gained from 1.6 ratio rockers from 1.5. My lift with 1.5 ratio rockers is .502/.510. Just wondering how much lift I will have with the 1.6 rockers. I have a set of LT4 springs and a set of comp cams 987 springs and was going to see which set to use on this motor.
Old Jul 26, 2005 | 10:47 PM
madwolf's Avatar
Re: How much more lift is gained from 1.6 rockers
535/544 with 1.6 rockers. Use the 987s.
Old Jul 26, 2005 | 10:59 PM
PUGHBOY's Avatar
Thanks.I'm going to need a tune too so I will hollar at you about that when its ready.
Old Jul 26, 2005 | 11:19 PM
LT1Squirrel's Avatar
lift/1.5=M
M*1.6=New lift
Old Jul 26, 2005 | 11:29 PM
Paul87's Avatar
I thought that was too strong of a spring for stock cam? I don't know much about it but I told my buddy I wanted to go with a strong spring when I got RR's so I wouldn't have to buy new ones when I got a cam. He said a stronger spring will cause the lobes on the cam to wear down faster, I called but never asked for a real explanation
Old Jul 27, 2005 | 06:48 PM
PUGHBOY's Avatar
Its not a stock cam.Its a comp cams XE 276HR-12. And you dont want to put comp cams 987 springs or so on a stock cam because it will cause premature wear.Stock cam or (cam with .525 lift or less w/ 1.6 rockers) the LT4 springs are the way to go.
Old Jul 27, 2005 | 07:45 PM
Paul87's Avatar
Thanks for answering my question, would putting 987 or similar springs on a cam like you have wear it faster (or wear like it would on a stock cam)? Always wondered this
Nutty's96
Dec 21, 2015 06:25 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
