Car won't idle when cold
Old Jul 27, 2005 | 10:28 PM
NeoSNK's Avatar
When I start it up the tach goes from 500-1000 and stalls out sometimes. Is there a sensor or something I could clean?
Old Jul 27, 2005 | 10:44 PM
phinger23's Avatar
Re: Car won't idle when cold
opti? coil? lack of fuel? start with those
Old Jul 27, 2005 | 10:48 PM
NeoSNK's Avatar
I've replace the opti and coil. If I give it a little gas its fine. I think its a sensor.
Old Jul 28, 2005 | 01:01 AM
white/blackss's Avatar
you could check the " idle control motor "
or i would check to make sure that the large rubber hose that has the maf doesn`t have any cracks in it. sometimes if there cracked the computer sees too much air and tries to compensate it. that might cause it to stall.
also, check for any vacume leaks, i believe you can clean the idle control motor with some gumout or something.
does the car have any codes?
Old Jul 28, 2005 | 02:19 AM
NeoSNK's Avatar
No codes.
Old Jul 28, 2005 | 09:36 AM
phinger23's Avatar
check for vaccuum leaks like posted above, also check your fuel filter, test for fuel pressure...it may be clogged/low pressure if its fine when you hit the gas.
Old Jul 28, 2005 | 05:00 PM
NeoSNK's Avatar
I figured it out. I changed the waterpump last week and apparently forgot to tighten the main clamp on the rubber intake hose, lol. That was an easy fix.
bfmv13trivium
Jan 14, 2015 09:57 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
