ICM- spacers or buy a new one
Old Jul 25, 2005 | 05:01 PM
co93z28's Avatar
ECM- spacers or buy a new one
Does anyone recommend moving the ECM away from the block or should I jus go get a new one ?
Old Jul 25, 2005 | 05:19 PM
93redbird's Avatar
Re: ICM- spacers or buy a new one
I think you mean ICM... ttt
Old Jul 25, 2005 | 05:21 PM
co93z28's Avatar
yes i do
Old Jul 25, 2005 | 05:25 PM
You don't give any info on a specific problem, so it might be hard for anyone to recommend a course of action. If you want to try spacing the ICM from the head, it will cost you next to nothing as compared to buying a new ICM.
Old Jul 25, 2005 | 05:29 PM
co93z28's Avatar
Well from what I've read so far alot of people are running into the same problem, after 20 minutes of running, car gets hot and starts fluttering and hesitating, so I was looking into this fix.
Old Jul 25, 2005 | 05:46 PM
romoranger's Avatar
mine is moved. it works good. i also have the hi-x coil on it
Old Jul 25, 2005 | 06:03 PM
BigJustinZ28's Avatar
hey shoebox , i put my grounds on the back of the coil icm mounting plate instead of the front , would this have any ill effects on the car ??? thx , i forgot how your pic was on your site as I dont have a printer.
Old Jul 25, 2005 | 10:04 PM
A ground is a ground-as long as it is securely attached and nothing is isolating it from what you are attempting to ground.
Old Jul 25, 2005 | 10:26 PM
Bandit95LT1's Avatar
where did you move yours to? i am looking into doing this.
Old Jul 25, 2005 | 10:45 PM
crazypurgatory's Avatar
Talking Re: ICM- spacers or buy a new one
I had to think a minuite on this post.
ICM
You could have just said "ignition control module".
Chris G.
Old Jul 25, 2005 | 11:35 PM
romoranger's Avatar
i will take a picture of mine in the morning
Old Jul 26, 2005 | 06:56 AM
MRBoss429x's Avatar
I have the same problem and have tried a new ICM and spacing the unit off of the head, neither worked. Hope you have better luck!
Old Jul 26, 2005 | 07:03 AM
I figured so , i just didnt know if it was better on the icm plate , i used 3 washers on each side , mine had 2 studs . thx for the site btw its an excellent resource as i try and figure out what is wrong with my car
Old Jul 27, 2005 | 05:26 PM
co93z28's Avatar
IF the plug that comes off of the ECM into the opti has gray powder in it does that mean theICM is bad or just the wire ????
Old Jul 27, 2005 | 05:28 PM
co93z28's Avatar
Icm
96SilverRam
Nov 20, 2016 11:19 AM
BLK1997Z28
May 2, 2015 01:26 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
maybe2fast
Mar 16, 2015 09:45 AM
