takes a while to turn over, SES light, need some help, may have found a few causes...
Alright guys, just recently I had a coolant leak, it was the waterpump. I have a new one in my garage waiting to be installed by a mechanic(I found all the crap you have to take off to get it off, I don't want to mess something up). Until then I added some leak stopping stuff and it seems to have worked, so I'll hope it works 'til after payday. When I was tearing it apart I noticed that the sensor that plugs into the waterpump was never even plugged in The base that it clicks onto broke off and is dangling with the wire. I believe it is the sensor that tells the fans to turn on, because my fans stay on all the time now Also I found that my intake bellow in cracked and I think it could be causing a small vacuum leak. So I'll be ordering an aluminum Trick Flow replacement so I don't have to worry about that again and I can eliminate that stupid tube that screws with airflow. Now I have an SES light and believe it's either the vacuum leak or the unplugged sensor. Finally I've noticed that when I start it cold it doesn't seem to want to turn over for a few seconds. Usually like 5-10 at most. I let the fuel pump finish priming so I dunno.
I bought a scan tool from Advanced Auto Parts. Its a cheap $25 one that basically makes the SES light flash on and off and you gotta decipher the flashes to tell what the code is. Well, it doesn't flash at all. When it's plugged in with the key in the OFF position, then the key turned ON the light doesn't even come on. But when you turn the key to the ON position and then plug in the scanner, the light stays on. POS thing...
Of course all of this happens right when I need an oil change and inspection
Re: takes a while to turn over, SES light, need some help, may have found a few causes...
A simple replacement of the coolant temp sensor may be all it needs.... and a piece of duct tape over the bellows.
Thank you Injuneer!! Thank God for A mechanic would probably charge me out the *** for that! Do you think Advanced Auto Parts would have the sensor I need? I'm going to go and check it out tomorrow. Grrr, gotta go to work at 5...
just to clarify, would any of these parts be an adequate replacement?
http://www.partsamerica.com/ProductL...erature+Sensor
from the looks of it i would have to take out the old sensor and splice the wires and solder them to the new sensor?
Likely, the plastic part broke off the sensor and you just need to unplug the harness connector from that. Install your new sensor and plug the harness connector to it.
Gtpguy
01-26-2015 04:50 PM
squarehead
01-15-2015 07:02 PM
sleeperZ96BT
06-05-2005 09:33 PM
