iron heads and 1.6rr's
Old Jul 27, 2005 | 08:21 AM
Digital Designs's Avatar
I have a iron headed LT1 and need to know if i would be able to use non SA 1.6RR's....... i know there is not a screw in stud to be used for a guideplate.
Old Jul 27, 2005 | 07:52 PM
96capricemgr's Avatar
Re: iron heads and 1.6rr's
To run non-SA you would need to pull the pressed studs and tap them for screwin and have them cut so there is a flat spot for the stud to clamp the guideplate too. Doable but not at home. The screwin studs can actually be done at home Proform sells a tool for pulling the studs and aligning the tap, but some go into the intake ports so the heads have to be pulled even if just going screwin.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
