LT4HotCam to CC306 worth it?
Old Jul 28, 2005 | 12:50 PM
belac350's Avatar
Will all this work be worth it? Car is set-up well now. LT4 Hotcam kit with ported heads, fuel system upgraded, headders, exhaust. Car made 350rwhp as it stands now. Upgrading to CC306 cam, 7/16 studs, large valves, comp r lifters. Hopeing to break 400rwhp.
Old Jul 28, 2005 | 12:56 PM
Fenster's Avatar
Re: LT4HotCam to CC306 worth it?
I think it would be worth it. You are gaining 12* intake duration and 12 * of exhaust duration.
FastZinTennessee's Avatar
Need to know what your heads flowed.
Also about the larger valves, I gained a little flow on the heads by going from the stock valves to the larger Manley RaceFlo valves. The opposite happened on the exhaust side- the stock exhaust valve flowed better than the Manley RaceFlo valve. I think the larger Manley exhaust valve shrouded a little more in the chamber which is why it didn't flow as well as the stock one.
Old Jul 28, 2005 | 01:05 PM
belac350's Avatar
Don't have flow numbers yet. CNC heads is doing the work. I guess what everybody else gets from his work would be a good guess. Car pulled 108 traps so it does run strong now
Old Jul 28, 2005 | 01:19 PM
jsetzer's Avatar
I know its not much to compare to, but my setup ran 109mph on a horribly slipping clutch. I am on stock heads. That was the only pass I made, and hope to make some more soon.
My friend that I got the cam from was trapping 114 with lt1 castings ported to about their max. He dynoed 396/375 through his 10 bolt, and lost a few when he went to the 12 bolt.
Expect stocish power below 3k. Nice pull up to @ 5500. 5500-6500 its a monster. Are you on a stock bottom end? How high are you prepared to spin it. The buddy mentioned above just spun a bearing spinning his 847 to 6800.
Old Jul 28, 2005 | 01:31 PM
belac350's Avatar
No, bottom end is not stock. Balanced and Blueprinted 353 (bored .020) forged pistons, well stock crank and rods. Pulls to 6200-6400 no problem but I know this cam wants more so that is why I am going to 7/16 studs, guideplates, 1.6 NSA rockers, double springs, titanium retainers, 10 deg locks. Trying to make the top end strong.
Old Jul 28, 2005 | 02:00 PM
T/A lt1's Avatar
I am running the CC306 and it works great both on and off the n2o. I only turn it 6500-6600 rpms. I am running 3/8th studs also. Goodluck. later Clint
Old Jul 28, 2005 | 08:37 PM
snakeatinZ's Avatar
you are going to turn that car into a monster!!!! you will love it. What gears do you have. The cc306 gets along with 4.10's nicly
Z Power
Sep 19, 2015 11:19 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
