Removing PCM
Old Jul 28, 2005 | 03:26 PM
HotNickeLz's Avatar
Exclamation Removing PCM
Hey guys. I have no where near the knowledge of cars as the majority of posters on this board. The information I need is: The proper way to of the PCM removal (Sending it to Ion for a tune). And when it gets back, what is the proper way to put it back in?
My mods include- TB bypass, K&N FIPK, TB Airfoil, Hypertech 160 thermo, Magnaflow exhaust system, stripped cats
Old Jul 28, 2005 | 03:29 PM
madwolf's Avatar
Re: Removing PCM
Here you go. Let me know if you have any other questions.
Old Jul 28, 2005 | 03:35 PM
HotNickeLz's Avatar
Re: Removing PCM
thx Ion.
on a side note. How long should I expect to wait for return of the PCM?
Old Jul 28, 2005 | 03:36 PM
2000GTP's Avatar
Re: Removing PCM
The PCM is located by the right side shock tower and you should begin by making sure the ignition switch is off and the battery is disconnected. The PCM is secured by two bolts, remove them and remove the electrical connections going into the PCM and your done. With the new PCM, reattach the electrical connector and bolts, hook up the battery and enjoy.
Old Jul 28, 2005 | 03:42 PM
madwolf's Avatar
Re: Removing PCM
Usually 3 or 4 days at the latest from the day I receive it.
Old Jul 28, 2005 | 03:43 PM
HotNickeLz's Avatar
Re: Removing PCM
one more question Ion- On your tuning order sheet. All i need to specify, for you to reprogram what temp the fan comes on, is that i have a 160 thermo;correct?
Old Jul 28, 2005 | 03:48 PM
madwolf's Avatar
Re: Removing PCM
Yep!
Old Jul 28, 2005 | 03:56 PM
HotNickeLz's Avatar
Re: Removing PCM
top-notch, thx for the help man
Old Jul 28, 2005 | 05:31 PM
lt11997's Avatar
Re: Removing PCM
Don't forget to take off the plastic braket on the PCM before sending it to Ion, there is a good chance it will break during shipping.
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
jayvar
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
