Miss after nitrous use
Old Jul 29, 2005 | 06:26 AM
SLeeper94Z's Avatar
Car devloped a miss, after nitrous use, ... well i decided to spray the car ince last night everything seemed to go smooth, and after the run my car was missing and lost power... I could still drive it I dont hear any knocking and its not smoking, and if i get on the car the miss smooths out a lil , Could i have burned whole in my piston, or burn a valve?
Old Jul 29, 2005 | 07:08 AM
Fujimo's Avatar
Re: Miss after nitrous use
Did you run colder rated spark plugs gapped correctly? I'd check them to see if they fouled out
Old Jul 29, 2005 | 07:19 AM
I'd check the plugs first to make sure they still have the ground straps.... first thing to go when you run lean, at least if you are using the stock plugs with the big heavy electrode.
Old Jul 29, 2005 | 10:42 AM
SLeeper94Z's Avatar
Well I changed the plugs a couple a weeks ago to Autolite 104's gapped at 35
also i hit the nitrous earlier in the day , and it hit fine also ,i felt a slight miss while i was using it , do you think it could be the plugs?
Old Jul 29, 2005 | 11:52 AM
Checking plugs should be a regular part of running nitrous. They will be the first thing to shows signs of impending (or current) problems with the tune. Hard to say if that's what it is without actually looking at them. You appear to have the right plugs. How much are you spraying?
Old Jul 29, 2005 | 02:19 PM
baddboy1705's Avatar
I'll bet you a wooden nickel you torched one of your plugs... i hope your running cold plugs and not the stock ones. check your plugs out...good luck
Old Jul 29, 2005 | 06:33 PM
FIREHAWK #7's Avatar
I wouldnt be comfortable hitting the n2o if you know there is a "miss"
Old Jul 30, 2005 | 01:15 AM
SLeeper94Z's Avatar
Well it ended up being I torched a plug on the passenger side 2nd one back from the alternator, Im glad thats all it was .. thanks for the help you all
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
