SES light on...Code P1444..whats wrong?
Old Jul 27, 2005 | 12:07 AM
Onebad97Z28's Avatar
Just recently fixed the SES light for P0441. Fixed that problem, now P1444 is poping. Anyone know whats up now?
Old Jul 27, 2005 | 12:14 AM
lt11997's Avatar
Re: SES light on...Code P1444..whats wrong?
I didn't see a P1444 on shoebox's website but there is a P1441.
P1441 Evaporative Emissions (EVAP) system flow during non-purge
Old Jul 27, 2005 | 05:33 AM
slopokrodrigez's Avatar
Seems you went from 441 which is no flow during purge to the opposite. 1441 is flow during non purge. There is no 1444 code. Perhaps your fix wasn't as good as you thought it was.
You didn't mess with the purple wire going to the evap switch did you? The difference in the 2 faults is 441 is that purple wire had a low signal and the 1441 is it has a high signal. Could be you had a 1441 the whole time but the wire was broke or bad connection? Then when the wire problem was repaired, it finally detected the 1441 fault? To fix that problem you need a scanner that can command the purge solenoid to come on and go off and then you have to check the status of EVAP switch to see if it's responding. You could also manually apply vacuum to the switch and see if it repsponds. However the switch must be checked while connected to the system to see if it responds to differences in the solenoids position.
Also we don't know anything about your vehicle To know if anything else might be causing your symptom.
Old Jul 27, 2005 | 07:12 AM
That code was already fixed, P0441. It was a bad charcoal canister. I know the code is not on shoeboxs list, which is why im asking for help...
Old Jul 27, 2005 | 08:39 AM
....I know the code is not on shoeboxs list, which is why im asking for help...
If the code isn't on Shoebox's list, its not a valid code. His list is OBD-II LT1-specific, and has proven very reliable in the past.
You could go to the AutoTap website and punch it in to see what comes up. You won't find anything .
http://www.autotap.com/codes.asp
Just maybe you read the code incorrectly? That's why we're trying to help
Old Jul 27, 2005 | 09:25 AM
Question Re: SES light on...Code P1444..whats wrong?
My goof, it is 1441. So, now what could be wrong??? Ive been dealing with this emmision crap for a month or so now. I have replaced the Purge sol, the Purge sol switch, and the charcoal canister. There is nothing more emmision wise to replace. When I installed the new charcoal canister, I also replaced all the rubber hoses under the hood, and blew the line runnning along side the fuel line out with an air compressor to remove any charcoal sucked into the line. What could possibly be wrong?? The whole system is new? I also put a new gas cap on...
Old Jul 27, 2005 | 09:29 AM
Dave89IROC's Avatar
it could be wiring, however, first, mke sure the vacuum lines are hooked up correctly at the purge solenoid, if they are backwards they can cause this, also, make sure the solenoid is still mounted right side up
Old Jul 27, 2005 | 09:54 AM
Frank89IROC's Avatar
Could be a bad gasoline tank filler cap.
Old Jul 27, 2005 | 11:27 AM
Question Re: SES light on...Code P1441..whats wrong?
Ok, checked the vacuum lines, all hooked up correctly, verified it by the markings on the sol indicating the line from the charcoal canister. The gas cap is brand new, it was replaced 3 weeks ago. All the wiring looks fine, no bare spots, kinks, burn spots. The sol is mounted the right way, it has a plastic catch that prevents it from being mounted upside down, and the same for the switch.
So, the code means that there is flow from the charcoal canister when there shouldnt be flow? Correct?
Old Jul 27, 2005 | 01:08 PM
Dave89IROC's Avatar
actually, it means the PCM senses flow when it is not commanding it
Old Jul 27, 2005 | 01:52 PM
So, does that mean the new purge sol is bad already??
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
