Just Did The I.c.m. Mod
today i finally did the icm mod and it workes great!
i really can feel the difference and the power seems to stay up there when the car is at normal operating range.
i really didnt think it was gonna make that big of a difference but i was wrong..
im gonna see if i can relocate the icm and coil assembly somewhere else though like maybe the fender wwell or something, i think it still is too close and getting to much heat.
sooo has anyone here moved this thing to like the fender or something?
is it worth the trouble?
and finally, since i moved the icm and coil and it made such a big difference should i think about replacing these soon? like the heat maybe has caused some internal problem with them.
thanks in advance
jim
thanks in advance
jim
Re: Just Did The I.c.m. Mod
Originally Posted by MRBoss429x
Basically tou just space the coil and icm off the head using washers so it doesnt absorb heat as quickly, thus operating better. Quick and easy to do.
thanks in advance
jim
thanks in advance
jim
The mod can be found here.
I don't know if anyone else had this problem with this mod, but I had
a bad run condition after doing it, but tracked it down to I put he ground wires up on the stud part, after I removed and put them back between the
head and the washers the car ran fine again.
Don't know it may just be mine but if you have the same just move the
ground wires to ground on the head.
I also have replacement studs( I think they are alum. so that could be the issue)
thanks for all the replys on this, for those who dont know what the mod is, shoebox has posted the link and his link is exactly what i did to mine.
it really does make a big difference on the surging and such that i was having, im still shocked that it made it run perfect
anyone here who has that surging problem on the 1994 car just HAS to do this cooling mod, it really does work sweet!!!
I think when I bought my new ICM, I tried driving around with it just hanging out in the engine and it made no difference. But you guys almost have me curious enough to space it out from the head permanently.
It's just that there is heatsink compound on there. That's an obvious sign that GM intended the head to be a heatsink for the ICM. Regular SBCs with the ICM under the dist are the same way...
