CC 305...What Springs?
Old Jul 27, 2005 | 07:47 PM
CamaroGuy22's Avatar
I posted this in a new thread to get more views. What springs should i use with a CC 305? I found online that you need Comp Cam part number #986-16 springs. But I could not find anywhere that sells them online. I found some on the board but the seller noted that they are not stock diameter and need machine work to fit? Where can i find springs that will work that i do not need machine work for?
Old Jul 27, 2005 | 11:00 PM
TransAm9585's Avatar
Re: CC 305...What Springs?
Get ahold of Combination Motorsports. They will have what you need and suggest the best for your setup. I used them when i did my CC305 and the springs they suggested are what i went with.
Old Jul 28, 2005 | 07:28 AM
97pontta's Avatar
When I did my cc305 install I contacted comp cams and got the spring recomendation from them, which was the comp 986-16. I just ordered all my valve train parts thorugh summit racing, unless they con't carry them anymore.
Old Jul 28, 2005 | 11:20 AM
I found them at summit. Thank you. Did you have to have machine work so they fit?
Old Jul 28, 2005 | 05:51 PM
97pontta's Avatar
nope, no machine work required
Old Jul 28, 2005 | 07:41 PM
Steves396lt1
Guest
Posts: n/a
Get the Beehive spring, COMP CAMS 915 or 918. It is a lighter spring , and has a lighter retainer which means less HP needed to compress them, which is more HP for you, and they can rev to a higher RPM without valve float.
Also, no machine work needed.
Old Jul 28, 2005 | 11:53 PM
raroz28's Avatar
A CC 918 beehive will bolt right up to an LT1 w/out any machine work to the heads?
Old Jul 29, 2005 | 12:22 AM
Steves396lt1
Guest
Posts: n/a
Yes. Just install at rigth height, which you do anywayswith shims, if needed.
Old Jul 29, 2005 | 01:31 PM
Thanks, do you know where the cheapest place to buy the 918 spring is? I am having trouble trying to find that also.
Maybe I am retarded but i have looked at combination motorsports, tbyrne, summit, and thunder racing and having found them there? Where did you guys get them from.
Edit - I just found them on comp for 228.96 That is way out of my price range.
Any other options?
Old Jul 29, 2005 | 02:11 PM
I did some more searching on this board and a few have mentioned this package:
http://store.summitracing.com/defaul...h.asp&N=400078
You get everything needed for 147 bucks. Would that kit work?
Also, somebody mentioned the EX-612-16 Kit from combination motorsports that i am currently having trouble finding...go figure...would that work also?
Old Jul 29, 2005 | 05:10 PM
Steves396lt1
Guest
Posts: n/a
COMP Cams sells them, like 180.
Big thing is make sure you get the right retainers. Make sure they know you have an LT1. The valve stems in LT1 are thicker than LS1's, which these springs were intended for. Go to the
http://forums.corvetteforum.com/show...gs&forum_id=48
retainer number is Comp Cams 787-16,
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
